Hi guys
Just been reading Kitcar, and one of the features was a westfield build. The text quoted that you now need an indicator on the top of the front
wheel arch. Does anyone know about this?
If it is the case it's back to the wiring loom again. If it is correct has anyone done it, how do you run the wire safely from the arch and
avoid moving parts.
the iva manual is very clear as to the placement/visibility/sight lines required for indicators.
maybe for most westies 'top of arch' is the only place suitable
but for those with innovation there's plenty of opportunity
They don't have to be on top of the wing... but the traditional position on the side panel or scuttle is obscured by the rear wing. As a result
they have to be mounted either high on the scuttle, screen frame, end of the mirrors*, front wing edge/top**. It's the downward angle thats
causes the issue (5deg I think). Most seem to be passing with them in the edge return of the front wings.
* note a lot of aftermarket mirrors with built in indicators don't meet the angles of visibility test.
** or even rear wing, though be careful of the max distance allowed from the front.
The problem with it on the wing is the wiring gets rotted away due to the wet days.
quote:run it with the brake flexy hoses
how do you run the wire safely from the arch and avoid moving parts.
quote:that's really for the side repeaters, but none the less very true
Originally posted by adithorp
They don't have to be on top of the wing... but the traditional position on the side panel or scuttle is obscured by the rear wing. As a result they have to be mounted either high on the scuttle, screen frame, end of the mirrors*, front wing edge/top**. It's the downward angle thats causes the issue (5deg I think). Most seem to be passing with them in the edge return of the front wings.
I seem to recall at least one person failing IVA for having front indicators on wheel arches as that one tester felt that when then the wheels were
turned the angles weren't met.
[Edited on 3-9-16 by loggyboy]
Originally posted by loggyboy
I seem to recall at least one person failing IVA for having front indicators on wheel arches as that one tester felt that when then the wheels were turned the angles weren't met.
By far the easiest way for IVA are little trailer side marker lights in the ends of your mirrors.
They have the added advantage of being easy to replace after IVA with "nice" mirrors and side indicators.
( Note to self. Must get mine on eBay before the garage spiders set up home in them. )
Paul G
[Edited on 6/9/16 by 907]
