Hi, I was planning on using a BMW 3 series steering column and stalks on my build but a small amount of investigation has revealed that the stalks
don't offer anything as simple as closed contacts for indicators or lights etc, I guess it must be a CANBUS or similar system? Does anyone have
any experience using these stalks and does anyone make an adapter to make BMW logic into good old fashioned analogue switches?
Thanks,
Chris
why not just use some other switches?
At least you know the indicators will have been barely used, full beam will be well used though.
Canbus will normally have 4 wires, if it is lin it will probally be 3 I beleive.
It must have simple switches in there somewhere. Open up the electronics box and see what's in there... I'd guess some copper strips from the contacts going into a circuit board. Re-engineer it to give you logic outputs
In the donor it is all processed by the LCM --- Lighting Control Module ---- don't even go there! it is unbelieveable over complex.
However has others have posted the LCM is simple connected to the switched by wires. Just add a couple of relays to the wiring as the switch contacts
and wire are unlikely to handle the full current
[Edited on 7/9/16 by britishtrident]
