Hi,
I have rewired my hazard switch from the Sierra stalks to a durite button type as per the thread listed below.
http://www.locostbuilders.co.uk/viewthread.php?tid=203699
I am now looking at having LED indicators on the rear and normal bulbs for the side repeaters and fronts and want to fit a Electronic flasher relay to
replace the standard Ford relay.
The questions I have is, the Flasher relay states that the max power for 12V Electronic & LED Flasher Unit - 3 Pin - Max.
30W will this be ok for the power drawn if the hazards are in use ie 4 bulbs plus 2 LEDS
Also, will this just replace the Ford relay or will I need to switch the terminals. Looking at the wiring diagram for these they state P goes to a
warning lamp and does not require earthing but as you can see that is different to how mine is wired (As per previous thread)
I don't want to use load resistors.
Thanks guys
[Edited on 23/9/16 by tims31]
Usually, indicator bulbs are 21w and side repeaters 5w... so thats 52w+LEDs with the hazards on.
I can't check right now, but I have a led flasher, but have the fronts as normal bulbs and the sides as normal.. IIRC the previous owner who did
it has reqwired the relay as the pins are different.
I reckon, as my relay hasn't burnt out, that you must be able to get higher wattage led flasher relays.
i'm not recommending this one but a quick search showed this one at .2 - 20amps:
link to random flasher relay
this should be suitable thou:
http://www.vehicle-wiring-products.eu/product.php/625/12-volt-electronic-3-pin-flasher-relay
(and since its electronic, shouldn't have an issue with the flash rate changing due to a different load.)
Why not put led bulbs in the fronts, no more problem
Can you just get replacement bulbs that fit the housings then?
I popped led replacements on the front of mine, ie just swapped the bulb. They were terrible, went back to filament.
Led front indicators bought as a unit I am sure will be fine, as are my rear led ones are.
There are some good alternatives out there amongst the rubbish. For indicators (front and rear) I've got Ebay 272353848435 -they're great. Can dig out the info on the side/brake lights if needed. I did try the very expensive multi-led "christmas tree" type but hated how they looked when on- the ones I've gone for look like normal filament bulbs, just use a lot less amps.
Those look completely different to the type I have tried!
The ones I used had lots of little smds on them.
Looks like the tech has improved.
371291284918 is what I used on the rear light / brake lights. Really bright and the red bulb in a red cover gives a pretty OEM light appearance. With a white LED bulb in a red cover you end up with pink brake lights...
