Which coil pack & leads?
snippy - 13/2/17 at 07:53 PM
Just wondered if anyone knows of a coil pack that comes with longer HT leads? I want to mount my coil on the ali shelf in front of the bulkhead but most coil packs seem to be bolted to the back of the engine and therefore have shorter leads. I'm using a 4age engine.
r1_pete - 14/2/17 at 08:35 PM
You can get longer ht leads made up for the ford coil.
Assuming 4 cylinder you could look at the range rover THOR engine coils, these have the advantage of using common or garden 3 way junior power timer pluga.
I do have a set of long leads for the early Ford coil with the external clips, let me know if you want the details.
