While waiting for the new bits for the MK to turn up I thought I would have a quick look at my 1980 Mini today which I bought some time ago for full
restoration.
Someone has installed a 1300cc Metro engine in it which has a pre engaged starter motor. They have then twisted wires onto the starter via the
original Mini solenoid. Am I right in thinking that the wire from the battery can now go straight onto the starter, the wire from the ignition
starting position switch onto the large terminal and all other wiring and bypass the original Mini solenoid altogether.
Maybe someone could do a diagram if I've got it wrong. Thanks
The only thing that complicates this is if you you have a ballast ignition system (quite likely if original). In this case the original solenoid will
have an additional low current (blade type) connection that is used to supply the full battery voltage to the coil during starting. It's most
unlikely the pre-engaged solenoid will have this connection, but it could be emulated using a relay whose coil is powered from the starter side of the
pre-engaged solenoid.
Otherwise what you wrote sounds correct.
[Edited on 19/4/17 by MikeRJ]
Thanks Mike.
