I'm onto almost the last wiring job, the reverse light. I don't have the two pin connector for the type 9 reverse switch. Any one any ideas
where to get one or recommend something that will work?
Mike
[Edited on 26/5/17 by mikeb]
pricy but there are some on ebay 201928617651
Seller assumes all responsibility for this listing.
[Edited on 26/5/17 by rash12]
Would a connector from a Focus or Ka fit? Should be easy to find one of those.
the female bullet crimp connectors just fit over the pins
I soldered two wires onto the switch covered each with heat shrink insulation then used crimp bullet connectors
Great thanks. I tried bullet connector over the terminals but didn't seem very good. Will try soldering
