Good morning all,
I am hoping that the Locost Collective may be able to point me in the direction of where I can buy a couple of connectors for this Ford WTS
online....... I've failed dismally so far.......
Many thanks in advance!
Doesn't help you, but i've just picked up my new one of these this morning, strange!
There was a website years ago that someone gave me which sold OEM type connectors, i'll have another look for it again as someone else was after
it but didn't have much luck the first time, maybe someone else on here remembers.
I looked for these but had no luck. In the end I ended up getting the plugs from a scrappy cut from the loom and splicing them in.
a scrappy would be the obvious place, should be hundreds to choose from!
Is it any of these https://www.simtekuk.co.uk/index.php/automotive_connectors/?k=:8::
See my thread here
https://www.locostbuilders.co.uk/viewthread.php?tid=194663
Have a look at TE connectivity. If you can work out the connector you can order free samples. I got cam, crank and oil pressure connectors all new for
free from them for the Duratec!
They look similar hopefully the same as denso injectors, if they are Ive a few, will check later.
