http://www.acewell-meter.co.uk/Acewell%20Speedometers/ACE-6xxx/ACE-6456.htm?action=full&id=222
As per the title all comments gratefully received.
Mike
I would have on of these if I had a BEC. For some reason a CEC with bike style clocks seems wired to me.
ETB DD2 lite is a nice dash but more expensive I guess.
I'm putting a new dashboard in next year and that is what I'm going to be using .it has all the features I want and is very good value for money .looks wise it might not be the prettiest but it's certainly not the ugliest .I've looked at lots and it's my favourite one .
I've got this one, works well and looks neat. It is smaller than I thought though and kinda wish I could've mounted it behind the wheel instead of in the centre,, but that's my fault not its
I bought the unbranded equivalent for £26. It lacks some of the features but as a basic dash its perfect
It came with a basic diagram and hall effect speed sensor. The gear indicator needs a switch for each gear (not bothered with it), and the fuel level and temp work with 10-50 ohm sensors i think. Ebay item: 172746081249
The dash doesn't have the brake test light needed for the IVA, I used the 7659 to avoid having a separate brake test light.
