Hi all
I have a sender problem, the one fitted worked fine but has broken off, any replacements seem to big at 1/8 npt which measures about 10mm plus with a
vernier, the one that has broken measures just over 9mm body and has a screw on type terminal with a black band on it, any one have any ideas what it
might be
many thanks
Seeing CVH in your profile I'm guessing it's a Ford engine.
If so either a Ford dealer or Burton Power should be able to tell you and most likely supply a replacement.
http://www.burtonpower.com/catalogsearch/result/?q=cvh+water+temp
erature+sender
[Edited on 20/12/17 by nick205]
