I'm going to invest in a lithium starter pack, has anyone on here got a view on good or bad ones, it's to start the kit so 2.0 zetec.
Shooter
Speak to Russ Boost (I'm now sure I've got his name wrong) he sells them via the furore web site. Decent bloke, I'm sure he'll make sure you get a decent one.
Ah, I don't think I explained myself very well, what I'm looking for is a jump starter for when the main battery is flat.
Shooter
If all you're looking for is a jump starter then I would be inclined to go for standard lead acid unless you really want the small space & weight of the Li ones. I think any of the Li at anything like lead acid prices are very limited in their capacity & CCA capabilities, they might start a car if left to put some oomph back in the standard battery first, but any of the beefier lead acid ones will start almost anything even if the battery is pretty flat
