One for those of you into electronics rather than specific car electrics.
I need a simple circuit - as simple as possible, which can sample a voltage ranging from 0 - 6v & can switch to provide an earth path at, or
within very close parameters, 3.85V - it mustn't ecognise 3.5V or 4.2V as being the same, so would need an accuracy of around 0.1V, preferably
adjustable for setting up purposes. Source voltage to power the circuit would be normal car electrics, so say 12.5 to 14.5V
Something ready built would be great, but happy to solder a few components together if required
Any ideas?
so you seem to want a voltage controlled switch.
strangely the 555 can be used for this:
http://www.circuitdiagramworld.com/led_circuit_diagram/Voltage_Controlled_Switch__NE555__2879.html
(which is a reprint of)
http://www.eeweb.com/blog/extreme_circuits/voltage-controlled-switch-using-555-timer
though you may also need an adjustable regulator lm317 to power the 555, and give a reference for the circuit.
Let me see if I understand the requirement.
You want a circuit that switches on at a very narrow voltage range about a specific voltage.
A low power schottky diode has voltage drop of 0.4v.
A voltage divider with resistors and the diode can be set to give voltage tap off at v +0.2 v and v-0.2v.
Lets say you choose resistors so v is 3.85, the taps are 3.65 and 4.05 volts, is that good enough?
Then two two voltage comparators who output is 'anded' can the driver relay to switch any voltage or current.
The voltage divide would need an accurate voltage reference, it may happen that there are zener diodes that differ by. 4v or less that can be an
alternative.
So yes, it can be done, and possibly simpler to what I describe above.
FYI. Some zener voltages, choose one for lower voltage limit and other for upper, not adjustable as the schottky diode divider as that can have a
variable resistor.
2V 2.2V 2.4V 2.7V 3V 3.3V 3.6V 3.9V 4.3V 4.7V 5.1V 5.6V 6.2V 6.8V 7.5V 8.2V 9.1V 10V 11V 12V 13V 15V 16V 18V 20V 22V 24V 27V 30V 39V
See https://de.m.wikipedia.org/wiki/Datei:Fensterkomperator.svg
[Edited on 26/3/18 by 02GF74]
quote:there are various 'dedicated' chips for changing lithium batteries that have exactly these parameters
or within very close parameters, 3.85V - it mustn't recognise 3.5V or 4.2V as being the same, so would need an accuracy of around 0.1V,
Thanks, for your input guys.
If I understand correctly then I don't think the circuit based on the 555 chip will work, unless that ratio of 1/3 to 2/3rds can be more
accurately controlled - surely it wouldn't be specific enough to define between 4.2V & 3.85V?
02GF74 you have described the requirement perfectly, unfortunately I don't fully understand the answer! My electronics knowledge dates back to
the time of transistors rather than IC's & is limited by the fact that I've forgotten most of it!
I do basically understand what you are saying, but I have no idea how to implement it in a practical way, is there any possibility you could draw the
actual circuit you describe. For instance whilst I fully understand the concept of a voltage divider & an output that is "anded" I would
have no idea what I would need to achieve this
yours dunbly Russ!
There are ways of doing this with a simple comparison circuit, the 555 or you can start playing with PIC's. The analogue input of an Arduino can
measure up to 1024 steps giving quite a granular reading, you would just need to find the correct setting for your application.
This site has a very simple Arduino circuit that measures
voltage
Your ground reference would be critical and as an Arduino can be as small as an inch square it's quite simple to build. The only issue is
protecting the Arduino analogue input from any potential over voltage, spike etc on the sensing port.
This is the Arduino Nano and your application is very simple but playing with the Nano could open a whole load of other possibilities!
Really don't want to get into anythiung as complex as Arduino (would love to find the time to play with these things!)
Can anybody tell me does this
6sAA
OSwLKpZgh8L" target="_blank">Ebay link
do what I want?
I would need it to be adjustable such that it will switch on (or off) at anything over, say 3.75V & under 3.95V, I'm not clear if that's
what it can be programmed to do???
Looks like it does quite a lot Russ, but I think your original request was for 3.85 volts.
From the description "External signal input: (5~ 12V) or passive switch" I read as being outside of your scope.
Oh ***%$^£"!!!
I saw it was adjustable, but didn't spot the parameters, presumably I could amplify the incoming voltages & it would then work? Is it
feasible to amplify a dc voltage, or is there a way, say 2V could simply be "added" to the incoming voltage?
I thought this would be simple!
Ok, would this
ebay link
amplify the input voltage such that I could use the voltage controlled switch previously linked to, or is my miniscule brain missing something else???
Depends on your definition of simple.
I will draw up circuit later this evening but need to know the voltage min and max for the switch to activate, if either of these is adjustable, then
need to know range.
Also an idea of the origin of the input signal and how fast it change: if it has noise on it, that can be smoothed but may delay response time to
switch.
I assume the circuit is powered from 12 v car battery.
I will draw up circuit later this evening but need to know the voltage min and max for the switch to activate, if either of these is adjustable, then need to know range.
Also an idea of the origin of the input signal and how fast it change: if it has noise on it, that can be smoothed but may delay response time to switch.
Hmm maybe, your dvm is averaging the voltage. Do you have any information about the sensor?
My gut feeling is that the signal is pulsed so not constant voltage.
I can draw up something but if pulsed then it won't work.
If it was pulsed would I not see that on the meter, it appears to give a consistent, continuous readout at a steady voltage, or are we talking about it being pulsed at high frequency?
after a little searching, I have found it common to use a gear position potentiometer
https://www.race-technology.com/wiki/index.php/HowDoI/UseTheGearIndicator
as I said before lithium batteries have a similar requirement, and a search found this circuit
http://www.circuitstoday.com/lipo-battery-charger-circuit
might work if you:
connect input to pin 2, and remove everything to the right of the led.
edit:
reading this
The gearbox sensor outputs 4.2V in 1st. 3.85 in N & 3.5 in 2nd reducing gradually to .77V in 6th
At a high level two circuits measuring voltage with an AND is what I'd expect, logically:
Input one is biased to be HIGH when voltage is >3.65 and low in all other states
Input two is biased to be HIGH when voltage is <3.85 and low in all other states
Two HIGHs = Neutral light on
I'll let someone draw the circuit...........but this
is what I would imagine would work with the correct resistors to provide the relevant switching levels.
I would suggest either:
A non-inverting a schmitt trigger with a regulated supply voltage (i.e. one that stays constant no matter what the battery voltage is).
OR
An Arduino board (built in voltage regulator) with some simple code to read the ADC and apply some thresholding and hysteresis, there is bags of
reference code online, it will be easier than having a circuit made. There are plenty of people on here that could help, myself included.
Note: don't use an OP-AMP unless its in schmitt-trigger configuration as otherwise the output will oscillate when the input is just on the
threshold voltage.
For either circuit you will want a solid state relay OR mechanical relay with a bypass resistor OR a FET with one side connect to GND to control the
output circuit - depends on how much current you want to switch.
The reason you need a voltage regulator or something like a Zener diode as a reference voltage is that otherwise all of your trigger levels will
change with the battery voltage.
[Edited on 27/3/18 by DanP]
The Arduinos I have lying around and could probably create one in an hour or so for you Russ if you want to try it out.....
Ok, many thanks for all the input, much to think about, I will buy some bits & have a play around, will let you know the outcome! (or should that
be output!)
Thanks for the offer Tim, trying to do it with "off the shelf bits" but good to know I could fall back to Arduino if necessary
sorry not got round to draw this up in full, but the voltage comparator is achieved by 2 op-amps and "anding" is done by diodes and
transistor.
Vut and Vlt are set by resistor network to give the 3.7 and 3.9 or whatever threshold.
Best to have it powered from 9 or 10 V voltage regulator e.g. 7809 or 7810 device, - this will be used a constant voltage source for resistor
dividers to set vut and vlt.
response to Vin.
An 8 pin DIL dual op-amp will keep it small and simple:
in your case the LED for the neutral lamp will replace R , with a series resistor to limit current through the LED to the 9 v supply.
read about it here.
www.electronics-tutorial.net/analog-integrated-circuits/op-amp-comparators/window-comparator/index.html
[Edited on 27/3/18 by 02GF74]
looks good, however, I disagree that the resistor divider reference should be powered by its own regulator*, it should use the same reference as the
pot on the gearshift. (probably raw battery voltage)
* yes if working with absolute values, but I don't think these are.
Yes, maybe but the requirements specification did not state the voltage from sender would vary.
Easy enough to check by measuring neutral with ignition on, engine idling at engine at 2k rpm.
I have been looking at typical bike circuit diagrams that use sensors like this.
and of course they are 3 wire sensors, +/- supplied by the ecu, and intermediate voltage returned to ecu.
so yes it will be feed from a regulated voltage ;-) so you could take it as an absolute voltage
Well, slow progress so far, the first circuit I linked to proved to be useless, I've had 2 of them now & can't get either of them to
read voltage, never mind set voltages that are required to differentiate between - the instructions are useless & when going into the settings
there are some there that don't even appear in the instructions!
I then purchased one of these
link which on the bench appeared to do what I wanted, however, when I fitted it to the car it immediately failed, I thought I'd shorted
something out, but on trying a second unit with a great deal more care, same result!
I think it is something to do with the way it presents & "looks at" the voltage, I suspect it might work if it was run from a completely
separate power supply, I think there is some sort of crossover on the earth path which effectively shorts something within the unit.
So, back to square one, have now ordered all the components to make one of the circuits suggested, will report back in due course
