i have a very strange problem which appeared suddenly:
if i turn on the ignition you can hear the indicator relais clicking, but instead of the indicators, the lights (front side lights, rear lights and
instrument lights) are flashing
if i additinaly turn on the lights (side or main) the relais stops, but now its impossible to get the indicators to work.
first i thought: hey quite an easy job...something wrong with the ground.....but i could not found any loose cable, i also temporary installed an
addtional ground directly from battery to front lights and indicators...nothing changed. i even disconnected the front lights to see whats happening:
the indicator relais is still clicking.
remved dash to see wiring behind....all wires connected where they should be connected.
lights work as they should, engine runs as usual, fan working as usual, brake lights work correctly, wiper and wiper-washer works correctly...
[Edited on 2/9/18 by alfas]
does it do the same when indicating left/right?
do the hazards work?
Try squirting the indicator switch with contact cleaner or failing that WD40 , it could be corroded contacts especially if you have been caught out in the rain. Guess how I know.
problem solved..... the centre pin of the indicator switch was connected to the dash lights...as i own the car only 2 weeks this must have been a problem already present at former owner ( he is insisting that he never touched the wiring, even he conformed that he had problems with the indicators)
