Hi All I have a escort GT instument pod , has anyone used one if so and pics would be nice and how was it for the SVA....Cheers
Going back to early days, this is what I did with the dash.
I swear I had a close up of dash but this pic is only one left with it on.
It doesn't look very padded but it was, there was 15mm padding covered with vynil. Bottom edge had a piece of plastic conduit glued on and cover
extended over.
I suspect you are trying to incorporate the GT pod though !
[Edited on 21/1/05 by Rob Lane]
Hi Rob,
My instruments came from a MK2 Ghia - is that the same pod as the GT? I'm not sure. Couple of pictures in my photo archive, I swapped the
speedo & tacho around to give better view of the speedo, no problems with SVA (well not with this .......!)
Cheers, Geoff.
[Edited on 21/1/05 by GeoffT]
