I know this isnt a kit car thing but this forum seems to be the font of all knowledge so here we go. One of my on going projects is a 16v conversion
on a classic mini using a BMW K1100 head, it's quite common so no problems with the main bits and pieces, one of the git bits is the tps which
comes with the throttle bodies, it's a twin track 4 wire Bosch thing which takes a flat blade I don't want to use, I've turned up a
slot to D drive converter so now need just a normal tps. The main problem is getting the rotation right and this is where you guys come in, the bodies
open clockwise when fitted to the engine looking at the end where the tps bolts so i need a tps which goes that way, i have been told a rover k series
will do the job, but would prefer if someone on here can confirm or recommend an alternative
Shooter
