I have read all the post I can find,
and am sure I have wired it correctly.
the engine is not running yet,
but with the ignition on the alternator is getting hot.
I have had the alternator tested and its fine.
I have connected it to a battery on the bench,
connecting the B+ to the battery and earthing the alternator everything is fine.
when I connect the switch live to the I terminal the alternator starts to heat up.
when I connect the L terminal to the negative side of a light and 12v to the other side of lamp,
spin the alternator with wheel nut gun the light goes out....
any ideas?
https://www.pinterest.co.uk/pin/626422629394212127/
sounds like you have it wired right , getting hot would suggest a short
I have had the alternator tested,
its a brand new one I bought as a spare,
the one on the car is doing the same.
am I looking for a problem that isnt actually there,
and is caused by the alternator being "excited" but not spinning...
can someone with a Denso please put their ignition on, but not start the engine and see if the alternator heats up.
You have a short somewhere in your system. When you connect the main lead does it spark?
How long are you leaving ignition on before it gets hot?
Probably 5 minutes..
I only have a red "missile" switch for an ignition.
So when ever the power is on,
The alternator is live..
Try putting an ammeter on the switch live feed?
I will try to get hold of one..
But what am i looking for?
If the alternator is getting hot then there must be a fairly high amperage going through it? Starterman on here is probably the best person to ask.
I must be missing something really obvious...
I have had it wired up to a battery on the bench,
With just a 25mm battery cable to post B+
A 1mm cable from the battery to the IG terminal.
A 1mm cable from L via led lamp to the positive of the battery. This operates as I would expect...
I am trying to think if I had the CTEK battery maintainer switched on, could this cause the problem.
Lets think about what is happening here.
The alternator converts mechanical energy to electrical energy and since no system is 100% efficient, the losses result in heat.
You say the engine is not running so alternator is not producing power so is not getting hot due to that.
When ignition is turned on, current is supplied to 'self excite' the alternator, this current goes through typically a 2 watt bulb.
You can work out the current flowing.
If the bulb is in, and it should be, then all of the voltage and hence power, all 2W of, are being dissipated in the bulb do the alternator should not
be getting hot.
Clearly there is a problem.
Im not familiar with the CTEK battery maintainer but remove that.
I d be surprised if that wad causing it as all it should fo us keep the battery at a slightly higher voltage and dissipate slightly more power in the
bulb.
Is the body of the alternator earthed?
If the bulb is in, and it should be, then all of the voltage and hence power, all 2W of, are being dissipated in the bulb do the alternator should not be getting hot.
I d be surprised if that wad causing it as all it should fo us keep the battery at a slightly higher voltage and dissipate slightly more power in the bulb.
Yes the body of the alternator is earthed
I wonder if the problem is I am using an led lamp as the charge light,
I will wire in a conventional filament bulb and see if that makes a difference
Originally posted by CosKev3
There is another connection on these Densos, an ignition live that is connected straight to the alternator as well as the excite wire
You need a resistor @50ohm 10watt in parallel with the led, and a diode In series to prevent reverse current.
If you are using a bulb on the bench and a led in the car there's your problem.
I am using an Led in both instances..
I think I will just add a filament bulb and hopefully that will cure the problem!!
If you want to use a LED on your dash then I think that you can fit a resistor to provide the load that the alternator requires.
But do some research, as I'm not 100% sure of what value resistor, what wattage it should be, and so on!
any ideas?
Take the bulb out, and put the ignition on, does the alternator still get hot? as if it does, the bulb issue is not the problem
any ideas?
It sounds like you have wired it correctly.
wiring is like this:
when alternator is not spinning lamp should be on, once spinning it goes off - exactly how you describe so all good and normal.
You haven't answered the question: how hot is the alternator getting?
If i leave the ignition on, the alternator can get too hot to touch
Give me a call if you want and I'll see if I can sort it for you.
01579 382391 Business hours.
Mike
Mike
What's the outcome?
To put closure to this...
I have rewired the alternator,
So that the IG switch live is now controlled by the Omex 600.
I have taken the feed from pin 87 on the fuel pump relay.
This way the IG is only live when the fuel pump is running.
And now the alternator doesnt get hot.
Thanks for all you help.
Good man
