My original starter motor has always struggled to turn the Zetec over when hot. Does anyone have a recommendation of suppliers for a geared 1.4KW
type? I can see what looks right on Ebay
---Link
I tried Starterman on here but looks like he's not around or missed my U2U.
Stu
I’ve had a few high torque starters from Power-lite. Always been very happy with their service. I don’t and haven’t had a Zetec but I’m sure they can advise on their most appropriate unit.
Thanks - a bit too expensive for me I think!
Which flywheel are you using? - the cvh type starter works with the original zetec flywheel (1.8&2.0), the pinto type starter is required for most
lightweight flywheels ie titan, raceline.
The one you've linked looks good as a cvh type replacement, the pinto type ones are a touch dearer.
Dave
I fitted one of these a few years ago - no issues since.
Running a Zetec 2.0 with flywheel from a 1.8, coupled to a Type 9 box.
https://www.ebay.co.uk/itm/273830331703
Hope that helps
Originally posted by obfripper
Which flywheel are you using? - the cvh type starter works with the original zetec flywheel (1.8&2.0), the pinto type starter is required for most lightweight flywheels ie titan, raceline.
Dave
Ah woops, didn't quite see that!
Same seller may have something suited for a CVH flywheel. Otherwise, your link seems a good option - 12 month warranty gives some extra confidence.
Common issue - root cause is mixing CVH and Zetec ignition components causing the ignition to be over adavanced at cranking RPM
It is the advance below 400 rpm that is critical -- it needs to very close to TDC
Got this delivered the other day and fits perfectly. Decent price as well:
Ebay link
Need to see if it fixes the issue when the engine is hot.
Thanks for the replies
Stu
