Can anyone tell me which production model of Toyota this alternator would have been fitted to?
It is currently on a 4A-GE engine in my Westfield, but has no identifying marks/codes etc.
It is not from a MR2 as these (and many other Toyotas), have the B-post on the side, not the back. This type will not fit.
Thanks in advance.
it,s a bit of a naf pic but most 7 type cars use a Denso unit from a kubota digger
[img]
Alternator
[/img]
[img]
[/img]
I know this one fits so I just want to replace like with like.
Especially problematic is the position/orientation of the B-post. In lots of these ND alternators it is on the side. That's no good for this
particular installation. It needs to be at the back, like in the photo.
deffo looks like a Kabuto one, have a look on fleabay as new digger engines come with the alternator but people take it off and flog it seperatley as
it,s brand spanking new
Pretty sure thats an Celica ST185 or ST205 (89-96) alternator, without the removable air cooling duct on the back. I'm not in the UK to check
mine, but as I scrolled past your picture my brain went "oh a GT4 alternator"....and then I had to check.
https://www.porza.nl/product/dynamo-alternator-herth-buss-jakoparts-j5112071?gclid=Cj0KCQjw5ZSWBhCVARIsALERCvzhHXN6F7LwxDGx_I2oUG1ramuRp6Rm6hGNA8H_I3u
iXNgpw6UX47gaArDdEALw_wcB
Here it is in its native home:
https://carbon-microsystem.com/engine-bay-toyota-celica-st205-st202/
It may be also from the non-turbocharged engines (3SGE instead of 3SGTE) in the same chassis package (ST183, ST202), basically any 89-96 Celica with a
3S- engine.
[Edited on 6/7/22 by coyoteboy]
With the improved (larger) images you can see the ND logo on it (Nippon Denso). Same as the Kubota digger alternator I used on my Pinto'd MK
Indy.
I made my own mounting for it so it fitted to the original Pinto engine block threaded mounting points (as the original alternator fitted) using a
chunk of 50mm x 50mm angle iron. Cut and drilled to suit.
Originally posted by coyoteboy
Pretty sure thats an Celica ST185 or ST205 (89-96) alternator, without the removable air cooling duct on the back. I'm not in the UK to check mine, but as I scrolled past your picture my brain went "oh a GT4 alternator"....and then I had to check.
https://www.porza.nl/product/dynamo-alternator-herth-buss-jakoparts-j5112071?gclid=Cj0KCQjw5ZSWBhCVARIsALERCvzhHXN6F7LwxDGx_I2oUG1ramuRp6Rm6hGNA8H_I3u iXNgpw6UX47gaArDdEALw_wcB
It may be also from the non-turbocharged engines (3SGE instead of 3SGTE) in the same chassis package (ST183, ST202), basically any 89-96 Celica with a 3S- engine.
Glad to have finally been able to answer one of these usefully
Recent thread on Denso alternators from Kubota tractors: https://www.locostbuilders.co.uk/forum/5/viewthread.php?tid=219154
Mike
