Just thinking about using my caravan battery when firing up the car just to save the bike battery and was wondering if there is any reason why this is
not a good idea, can't see it's any different to a jump start but wondered what others thought.
ta,
Rich.
Not a good idea, as they are designed to be used in a different way.
A car battery is designed to spend most of its life fully charged, with occasional discharges at very high current (starting), then fairly rapid
recharge back up again.
A caravan battery is designed to allow continuous discharge at modest currents right down to a fully discharged state without damage. They are not
capable of supplying 200-300 Amps for short bursts.
It would be better to get a cheap-and-cheerful car battery from your local motor factors, or even a battery in good nick from a scrappy (e.g. from a
newish car that's been shunted - not rolled! )
rgds,
Thanks David,
Had a think about it last night and came to the same conclusion, best to just get a cheap battery from halfords.
thanks for the advice,
Rich.
