Green Gauges speedo
Trev Borg - 10/3/05 at 08:07 PM
Ok just bought a green gauges speedo off e-bay.
What do i need to get it work correctly?
Its gonna be fitted to to the alfa V6, with a type 9 box.
I assume i have to buy sensor kit from them. Which one.
andyharding - 10/3/05 at 08:18 PM
I've just ordered their speedo and the reed switch sender.
evo3500 - 10/3/05 at 09:38 PM
Hello Trev,was just wondering, as i have pondered using v6 alfapower before, in kit cars,how do you get it to mate to a type 9 ford gearbox,what parts are needed to do it ,ie starter mtr flywheel clutch etc.would appreciate the info,also what vehicle ford vehicle does a type 9 gearbox come out of
Thanks Simon
(currently building mkgt1)
Trev Borg - 10/3/05 at 10:18 PM
Engine, starter = Alfa
Type 9 = ford sierra (long shaft fron V6 but either can fit)
clutch plate = mondeo / focus TD
bellhouse = homemade ( if i get enough interest, i will get some cast in alloy)
Cheap way of getting 200 BHP
Avoneer - 10/3/05 at 11:05 PM
Is it the electronic or mechanical one?
Pat...
Ian Pearson - 11/3/05 at 11:07 AM
If you have a look on the Greengauges web site,they've a section on sensors.
HTH.
Greengauges
