Can anybody confirm that the reversing light switch on the type 9 gearbox switches live not earth
It will switch either depending on the way you wire it. Its just an on/off switch
Pretty sure its the live though, earthed at the light cluster
Graham
[Edited on 1/4/05 by Bart69]
OK thanks.
Vaguely on this topic - do you have to use a Sierra plug on the pins, or do bullet connectors fit?
[Edited on 02.04.2005 by Humbug]
i saved the plug that gose on it with a long bit of wire to go in to the engine bay hope it helps
if you switch live, it saves an earth wire through the transmission tunnel, but as has been said, it's just an on/off switch so doesnt make any
difference.
tom
