I have wired up a Telemetrix guage to the right sensor on the termostat as you look at it. It worked for one day when it went up to 100 degrees, now
it won't go over 60, even though the Polo sensor controlled fan has.
Any ideas? Can you replace these sensors?
The XE thermostat has 2 temp sensors in it, the blue 2 pin plug which is the coolent temp sensor for the ecu, and the single round connection for a
spade connector, which is for the dash display.
Both can be replaced. www.autovaux.co.uk are cheap for all Vauxhall parts.
