More progress towards running my engine.
In order to get power to the gauges, water and fuel pumps, fans and engine ancillaries, I made up and wired a dummy dash. This will also help me
decide on eventual dash layout.
[img][/img]
Here you can see the relays, fuse boxes and an earth "buss bar" on the back of the cut out switch
A good 2 days work I thought
Fred WB
[img][/img]
Looks good Fred, I'd agree,a good couple of days work!
I've heard of a Walnut dash in Bentleys and the like.
Good to see you're keeping with the Locost philosophy, and using ply
Simon
Don't believe that Simon. $$$$$
Everything except the flywheel is a mock-up.
Hay Kango - You are just worried I am catching you up
After that crack I may just have to start a poll "Who has the most irritating avatar?"
Fred WB
[Edited on 5/9/05 by Fred W B]
I am catching you.
And just to show you what my avatar looks like .
Looking good Kango, will pop in soon to see for myself
Fred WB
Red line at 5k???
Pat...
I know
Ask for some help in another Post. It is a 6 Cylinder Rev counter, so it should read lower than indicatd.
Is it possible to change the face of the Rev counter to suit the 4 Cylinder?
