Some Pics of my Megasquirt project running on the Stimulator.....
megasquirt1
megasquirt2
megasquirt3
Ray
[Edited on 20/11/05 by rayward]
Looks good.
Where did you get the extruded alli box from that the MS is housed in?
Got the box from Maplin Electronics
Ray
did you build it yourself or buy it in?
How have you found it so far - medium term aim is to go megasquirt (short term is to get the car on the road - yr 5 already)
which version did you go for? v2 or v3, mega squirt'n'spark etc
Built it myself,, its a V2.2 with the MSn-S installed, its going on a Turbo'd Zetec eventually.
Ray
Looks good
I´m gonna order the parts myself soon for my Pinto
but i only cant imagine an Throllte % of 107 if 100 is max..??
would deff have to make wich powersupply/res values..
Anyway looks good/fine..nice case!
Tks
Megasquirt can handle different resistance throttle position sensors - Ray has yet to calibrate this, hence the odd figure.
I've today upgraded the firmware in mine to the MSnS extra. LOTS of new features in this, including launch and traction control, etc. (Using a
Xflow.. who am I kidding....) Should keep me busy for a week or two.
GeoffT,
The traction control may prove valuable for those slippery winter jaunts.
RayWard,
I find it useful to use a syringe to generate a vacuum on the MAP sensor.
Just make sure you wash that nasty white powder out first.
Nice work bet you were nervous first time you gave it 12volt :-)
Hi Geoff
I am fitting Megasquirt to my 1600 crossflow , im using kawasaki 35mm throttle bodys and am going to build a megasquirt and edis version.Do you have a
working Map that I could use to get it started?
Paul.
Originally posted by GeoffT
(Using a Xflow.. who am I kidding....) Should keep me busy for a week or two.
Paul,
Hopefully yes, depends, really, on which version of MS you intend to use, will u2u more info Monday.
