Hi, just been testing the electrics for the first time. I've already corrected a couple of things including the flasher relay and changing the
full beam circuit so that all the other lights don’t have to be on to light the circuit. We now just have the problem that both the two displays on
the blade clocks, the mileage and the temperature are reading blank. Anyone got any ideas what i've got wired up wrong? Can't see anything
obvious, the clocks have power as the neutral and oil pressure lights are on and the illumination works.
Thanks in advance
Ed
1st electrics test
[Edited on 12/3/06 by esn163]
