Can anyone advise on where I can buy a cheap fuel level sender please? I am looking for one with a 6-hole pattern (as I already have this pattern of
rivnuts in my tank) and the adjustable float-arm type.
Also, I assume that the resistance change from full to empty on these senders is linear? I'm gonna be using it with an electronic dash display
where you can manually define the resistance range.
Would have liked to have used the dip-tube sender which does damping, but these seem to have the 5-hole pattern and a slightly smaller PCD. Plus
they're pretty pricey!
You should try any of the regular kit car supply places, www.lolocost.co.uk and Car Builder Solutions www.nfauto.co.uk for starters!
Caber
Originally posted by Ferrino
Can anyone advise on where I can buy a cheap fuel level sender please? I am looking for one with a 6-hole pattern (as I already have this pattern of rivnuts in my tank) and the adjustable float-arm type.
Also, I assume that the resistance change from full to empty on these senders is linear? I'm gonna be using it with an electronic dash display where you can manually define the resistance range.
It depends on which gauges you are hoping to use. My suggestion would be to get the sender to suit the gauges so this ensures they read correectly. I
got a sender to suit my tank, then had to get my gauge modded to suit the range of the sender!
Ned.
Another vote for Landrover ones - the one I used has everything built into one unit - pump, swirlpot & sender unit.
Originally posted by ned
It depends on which gauges you are hoping to use. My suggestion would be to get the sender to suit the gauges so this ensures they read correectly. I got a sender to suit my tank, then had to get my gauge modded to suit the range of the sender!
Ned.
