any body using one of these?
need to know the wiring for it as i can not get the reed switch to work please helllp
cheers
ACE-3100
I have one, but its 100miles away and I cant remember how to wire it up off the top of my head.
You should have had a wiring diagram come with it. Along with the general instructions. One end of the reed connects to the dash, the other connects
to ground i think.
Sorry thats not much help...
now i have the 28 series wiring diagram infront of me , ASSume its the same
Speed+ = Green wire
Speed- Black
they match upto the following wires on the sensor lead :
Green - Red
Black - White
HTH
Matt (aka16vmini)
Matt, you're not the RWD mini man that posts on Valvers are you?
If so, Hello!
I am the NS Dev that posts on there!
If so, Hello!
