can any body expain this wiring diagram to a simplton from dudley?
got power and rev counter working but can`t get the F*****G speedo to work. Text
Connect one side of the reed switch to the green wire, the other end to ground.
Should work then...
will try it cheers
what about the brown wire?
all working. i have a speedo first time
many many thanks
tom
Should work then...
Well i assumed he knew that!
