Anyone know what terminal is what on this Alternator. It's off a Suzuki Vitara.
Many thanks
Chris
Another view just for general identification...
It is denzo yes.
The big one is the main output.
The three connection on the plug are one for the dash light, one for the field exciter and one additional output.
Sorry I do not know which is which but could look some time this week.
The exciter wire needs to be live with the ignition on but not while cranking the engine. This may be a problem as alot of cars only have a combined
exciter and indicator light wire.
I'm not sure what the second output wire on the plug is for but I tested it through on my toyota loam and it connected to the main poer output
wire that connects on to the big bolt.
Thanks Rusty but it's not a Denso, it's a Mitsubishi. Have a look
HERE towards the bottom, its the same as HTSP0975.
Anyone know which connector is which?
Chris
as viewed from the back....
turn alternator until plug is this way
__
top one is not used, left one is Ignition, and one on the right is the warning lamp.
and the studded terminal is the B+ (battery)
Kevin
Thanks Kevin and welcome aboard!
I have seen that configuration on a Denso alternator HERE, is it coincidence that
its the same for a Mitsubushi one or is that where you got your information from? Don't want to appear to be doubting your wisdom but I would
like to have some level of confidence before connecting it up wrongly!
Thanks again,
Chris
Hi Chris,
I work for a Motor Factors, looked it up in the Lucas Catalogue!
Originally posted by tigersupercat
Hi Chris,
Hi Chris,
I think that must be a standard Jap type conector as out unit is off a toyota.
Just a note about the ignition connection on our engine it is def only connected to the ing 2 ie not powered while cranking.
surely ign 2 is on while cranking or the engine won't start as the coil is usually off ign 2?
A bit late I know but I'll post it anyway
Has anyone got a connector to fit this plug?
