Hello all I'm at the wiring stage and was wondering, what wires are used from the EDIS when using a Mega Squirt?
I presume Live,Earth,SAW and PIP signal.
But what else?
A wiring diagram would be good.
Here you go piddy....
Plenty of reading HERE too
Chris
Thanks Chris.
Do you know wheere I can buy the connection plug to fit the coil pack?
I got one by posting a wanted thread on this forum, otherwise the scrappies are probably the best bet.
Chris
I've been told from a member of the Mega squirt forum that this diagram is incorrect! pin 10 should go to coilpack 1 and pin 12 to coilpack 3. Anyone esle found this to be the case.
