Hi
Has anyone used the standard Sierra fuel sender? If to how have you fastened and sealed it in the tank?
Stu
I cut out the hole from the top of the Sierra fuel tank (if you see what I mean!
) and used this as a template to draw around on the Locost
tank.
I then chain drilled and filed until the Sierra sender fitted.
It sealed by using the Sierra sender gasket.
Take care when cutting the hole in the tank. The Sender is a twist fit so you want to cut a hole that means the sender ends up the right direction.
Hope that helps,
James
Thanks James - very helpful.
I should have taken more notice when I took it out of the Sierra!
Stu
