Surrey based Thatcham installers
nitram38 - 1/4/06 at 04:13 PM
Anyone in Croydon/Mitcham area with Thatcham approval?
I have fitted a Sterling (toad) immobiliser to my project and I am after the paperwork to be signed off.
I am an electrician. The original wiring was stripped back 300mm, the new circuits soldered and heat shrinked. The loom was then re-wrapped and spiral wrapped.
There are some pictures in my archive.
Without using the transponder, the complete engine management circuit is isolated, so there is no ignition, fuel pump etc. The second circuit is the starter motor. All that works is the dash lights when the ignition is on.
I can't bring the car to you until it is insured. To get reasonable insurance I need the immobiliser..............
Regards Martin
[Edited on 1/4/06 by nitram38]
nitram38 - 1/4/06 at 05:13 PM
Originally posted by chris mason
sign it off yourself, i did on my 1st one
if your competent enough to wire the entire car in the 1st place adding a simple immobiliser is childs play.
you could even say it's "factory fitted"
Chris
I don't want to give the insurers any excuses not to pay out if I have an accident. The thatcham certificate is also recorded as it has to be sent off. (I think)
k33ts - 1/4/06 at 07:07 PM
its not recorded know one will ever know
if your really worried about it can you not take it to a local installer or check the yellow pages for a mobile one.
therell prob charge £40 for the honour though
nitram38 - 1/4/06 at 09:03 PM
Cheers!
