OK
Now I'm no sparky but at long last I've started what for me is the hardest part of my build and I'm stuck already....
I’ve got Luego’s wiring loom (& instructions), bought some 18 months ago (God is it that long already?!!!)
So here's my question’s to date;
1) Instructions say starter motor solenoid should be white/red BUT I can't find a white/red, only a white/grey...any ideas if there is a mistake
with the instructions or does any one have any other ideas?
2) I'm using a ford coil pack with my 4age, so should the white for the Coil +ve go to the coil pack along with the white/black for the Tacho?
Coil pack req’s 3 wires, so I’m guessing that the other is the live feed from my ECU (when I get one).
3) Handbrake switch should have a black/white wire, again can’t find this colour wire ANYWHERE…any ideas?
4) Brake fluid level also requires a black/white (2) wire, again can’t find this ANYWHERE.
Thanks in advance, I'm sure I'll have more Qu's soon
Rich
Hi.
My Luego loom has White/grey to the Starter motor solenoid.
I'll check the colour (s) of the handbrake and Brake fluid level switch tomorrow for you.
I don't know Luego colours but might help with circuits. The ford coil pack should have an ignition live supply and two switching wires from the
ECU. Tacho take off would usualy be from the ECU.
The hand brake switch wire (Bk/W) in your instructions is the other end of one of the wires at the low fluid sensor. The other Bk/W there goes to the
warning light on the dash so you might be able to find it or work out its colour from all the other dash wires?
Hello again.
The wire to my hand brake is Black/Grey
The wires to the brake fluid level is black and black/grey.
