free wiper wiring diagram
Julian B - 2/5/06 at 10:29 PM
Hi all
If any one is interested ( and is building there own loom ) i have put a cut down version of a Sierra wiper system wiring diagram on my web site.
I should have a basic overall diagram up there aswell fairly soon .
Julian B
wiring page
Dusty - 2/5/06 at 11:31 PM
P on the intermittent relay should be 12 V variable from the variable control rheostat and 31 should be earth not constant live
Julian B - 3/5/06 at 05:53 AM
On my diagram 31 is shown as busbar to give the intermittent relay its constant supply, but canany one else shed light on this . Can anyone else also tell me what the value of the pot for the variable delay should be
Julian B
Dusty - 3/5/06 at 08:08 AM
31 is negative busbar. 31 is the usual number used by Ford on wiring diagrams to denote an earth connection, just like 30 is battery live and 15 ignition live.
There is a fixed intermittent wipe relay available from escorts and early base model sierra's (?many base fords) does away with the P connection but otherwise has identical pins and numbers.
Sadly threw away the variable pot about five years ago cos I couldn't get it to work!
Julian B - 4/5/06 at 07:34 PM
Hi Dusty
I have had another look and changed the diagram to show the negative busbar ground.
I have managed to get a couple of relays one with a p and one without, I will have ago and see if i have any luck with pot values.
Thanks again for your input
Julian B
