Ignition leads Pinto & Coil pack
DarrenW - 3/5/06 at 08:25 AM
Can anyone tell me what the best ignition leads are for a pinto engine fitted with Megajolt and Zetec coil pack please?
Im waiting for a Mondeo coil pack to be delivered with some leads but dont know if they will fitonto pinto plugs. I heard that you need either a specific type or custom made ones - can anyone shed some light on this please.
Darren.
muzchap - 3/5/06 at 09:05 AM
Hmm the problem you'll have is that the 'Mondeo' leads will have VERY LONG plug connectors on them - as the mondeo is 16 valve and the space from rocker cover to plugs is quite large.
The Pinto is a lot shorter. I mistakingly got some ZETEC-S leads - these are much shorter and can be found on the Fiesta Zetecs etc - These might do the job nicely. I have an 'electric blue' set if you want em
Best advice is to see how far out they are (Measure) - then pop to scrapyard and then measure as many leads as possible.
[Edited on 3/5/06 by muzchap]
paulf - 3/5/06 at 10:56 AM
Fiesta leads are quite usefull , especially as there are loads in scrapyards and it is easy to find good ones , it is possible to get the lengths you need by removing the ones nearest the correct length from a nuber of cars to make a set.I have also used some from a CVH Sierra that had edis fitted
Paul.
DarrenW - 3/5/06 at 11:06 AM
Thanks all. Murray i think your Fiesta leads might just be the thing. How much do you want for them?
muzchap - 3/5/06 at 12:09 PM
To you mate - £5 + postage?
They're practically brand new - just had my grubby hands on
I'll even throw in the coil pack as well - how does that sound?
TangoMan - 3/5/06 at 09:56 PM
I just squeezed the dizzy end of my leads togther a bit so that they fit into the coil pack.
I do need to get a set as they are too long but haven't had time to go scrap yard hunting for options.
I guess lengths will depend on where you have the coil pack fitted.
