hi all i am at the stage where i need to mount the trig wheel and vr sensor. i have come up with this picture as a picture is more clearer than me
trying to say what i mean.
so can anyone help is this the correct position i should have my trig wheel. i have put the vr sensor on the exhaut side of my 4age, so it is 90deg
after tdc, the missing tooth is at the bottom, which is opposite tdc.
if this is incorrect please correct me as i am not sure on this one,
thanks
rob
forgot the bloody pic
i thought it was 90 before tdc? well mine is and it works.
i put mu engine at 90 deg before tdc then removed the tooth under the sensor
my vr sensor is after tdc as it has no room on the otherside. i need to know if this is correct if not i need to be corrected as i dont wanna screw
things up.
anyone ??
this is what it would look like when the missing tooth is aligned with the crank sensor. does this help???
thats how mine is as long as the car is at 90 before you can have the sensor anywhere as long as the missing tooth is under it
thats what i thought but was just making sure as i never done this before so just want some reassurance, thanks for your help though. also im now an
official builder as i just went past 100 posts woohoo
That is correct , the missing tooth needs to align with the sensor 90 deg before TDC which is how you have it. It does not matter where the sensor is
as long as the relationship is correct.
Paul.
weh hey was waiting for paul to post as you are the man that made my megajolt! i will let you know when it is up and running, also need a map for 4age
on twin 40 dellortos if anyone out there has done it , to save me bit of work like.
cheers guys you just prooved that i was correct and am thinking straight!!
