Fuel gauge NEEDED
DIY Si - 9/7/06 at 11:48 AM
Firstly, sorry if this should be in the wanted part.
Basically, I was on the way home from a mate's house last night when I ran out of fuel. Admittedly my fault for not dipping the tank before I left, but I foolishly assumed £15-20 of fuel would last a whole lot longer than it did. Basically, I'm no longer a happy bunny having been stood on the side of the M40 in the rain with the missus whilst waiting for a friend to arrive with some motion potion. So, is there a simple/easy but not overly expesive way of getting a fuel gauge, other than buying a gauge and sender from vdo/smiths etc?
rayward - 9/7/06 at 11:53 AM
Hi,
first thing is, do you have a sender/hole for a sender in your tank??
if not that could be a problem.
what about a low fuel warning light in stead of a gauge, may be cheaper to do.
Ray
DIY Si - 9/7/06 at 11:55 AM
As far as i know, the tank is a standard plastic MK(?) one. There's no hole that I've seen so far.
nitram38 - 9/7/06 at 12:04 PM
If you want a simple gauge, buy a boat tank gauge.
They are simply a spiral float with a gauge at the top.
You will only need to cut one hole into the top of the tank and drop it in.
Like this one on ebay Link
[Edited on 9/7/2006 by nitram38]
DIY Si - 9/7/06 at 12:06 PM
Ideally it need to be visble from the drivers seat. I'll be making a boot soon, so the tank'll be covered.
MikeRJ - 10/7/06 at 07:04 AM
I don't think there is a simple way around this, you reaaly need a guage and a sender, and if the tank dosen't have a hole for a sender you will need to cut one.
DIY Si - 10/7/06 at 03:24 PM
Bugger. Was hoping there'd be another way. Oh well, out comes the cheque book again.
stevebubs - 11/7/06 at 07:01 PM
Bungee a petrol can into the engine bay / luggage area.
When you run out of juice, get out, top up from the "reserve tank" and head for the nearest petrol station.
DIY Si - 11/7/06 at 07:04 PM
That was the first thing I did when I got home! I'll be building space for one into the new boot.
