Is it OK to place rear lights strait onto wing or do we need a 'wedge' to bring them up perfectly vertical.
Anyone suggest some good budget units?
i put our light flush to the rear wheel arch and dont have a problem at sva
but be warned the fog light has to be vertical to the ground
joe
Only the fog light needs to be perfectly vertical.
Mounting on the wing is not a problem (for SVA anyway, check clearance depending on the style of light)
Budget units are available from the usual suspects.
Best to buy from a show (Harrogate 12-13 Aug if you are close) so you can get a feel for the quality and avoid the postage.
Try:
http://www.s-v-c.co.uk/
http://www.vehicle-wiring-products.co.uk/
http://www.premierwiring.co.uk/
and of course
http://www.ebay.co.uk
i can do you a full set same as fitted to the back of mine with reflectors(without vertical plynth) but plain black plastic ones for £55!!!
