Are they all the same? Im fitting my digidash and the water temperature sensor is a different thread, will the origional one do the same job or will I
get a wrong reading, the same goes for the oil temp,
My current reading when cold and using origional sensors is 16 oil, and 30 water.
Does this seem right?
My Evodash needed bosch senders to get the range right and I had to make adaptors to get them to fit, so you may find a similar situation with your
Digidash.
You should be reading ambient on both senders assuming your engine is stone cold so you may have a calibration / range problem
*edit* Just realised that you probably mean oil pressure and ambient is 15psi so more than likely ok.
[Edited on 21-10-06 by RazMan]
