At work (at a garage) we had a part ex come in with said alarm on that was going to be traded for a couple of hundred, so i had the alarm out. Its all in working order but basically i could do with the wiring diagram to get it into my car. Any help would be appreciated. Jon
Hi mate
Had a clifford in my old tin top and most wires are black so unless installed from new with indicating tags i think you will struggle highly
Thats why there so expensive to install and buy
Only help i can give sorry
You could try asking at www.the12volt.com under the car alarms bit. I did for a clifford immobilser and it worked. Owners guides can be found at
www.clifford.com/guides/other
Hope that helps.
Cheers Mike
Right. After some gueswork and two fuses i have it basically going. Just want to be fancy and wire it up so i can start my car from indoors etc. Tried the clifford site and it only goes up to the 600 series. but thanks for the replies people!!
And we have lift off. If anyone ever needs help with one....
