those of you that were alarmed by a pall of acrid black smoke hanging over west london....fear not its only moi doing my wiring
on the EDIS the signal wires are sheilded like coax,my mundano lumd didnt have shielded cps wiring,do i need it?
If the Mondeo didn't have shielded cable for this sensor you'll probably get away with it if you route the wiring well clear of any
'noisy' stuff, i.e. HT leads, coils, alternator, etc. But my feeling is why risk it - induced noise on this line (and the TPS line) can
produce spurious faults which can be difficult to diagnose, so for the the sake of a couple of meters of shielded cable I'd be inclined to play
safe
PS. The smoke has just about cleared now at Windsor....
Geoff.
The smoke has all gone in ashford too,probs safe to go in the garage now.
a wild stab in the dark,maplins might be the best place for shielded.
I'll need a bit myself so i'll trot down there in the week if you want john
got some at maplins,i,m about to see if she will fire up,have sparks and a flatish battery at the mo,tea break me thinks
she runs.......but
acording to my noid light the injectors are firing but i have to squirt fuel into the bods to get her running,could this be no programe in the
megasquirt ecu?
oh and 2 of the red neon,s flash when she runs.
Well done mate! You must have got some sort of program loaded for it to run at all. What you need to do now is fire up megatune and setup all the
various parameters to suit your installation. It sounds like your sparks are working, but you'll need to setup the fuelling side. Basically this
means setting up the 'constants' file and then getting some sort of fuelling map loaded. Time to RTFM I reckon!
Good luck, Geoff.
thats what i recon Geoff,wait till Christmas and robocog to bring his lappy over
Stick a laptop on yer crimble list Jon, you're gonna need one.....
Squirting the fuel in by hand might get a bit hectic when you want to go fast Can't you drag the desktop computer out into the shed to tune it John ?
ive got long arms and used to be a boy scout,i can do ANYTHING given enough tea and lo-cal bacon rolls
