Hello chaps,
could really do with some help on a megasquirt system on me rover v8.
managed to pickup a full system which has been tried and tested on the engine and ran sweet, but the seller labled what each wire niceley on masking
tape, and after a month.. iv judy gone to start playing and the inks dissolved.. theres 3 wires.. coming from a block of relays.. anyone have any
idea how i would work out what each one is... if you need photos let me know and ill take a load ..
cheers
GEOFF
Hi Geoff.
Doe's this help.
Sounds like you're describing the relay board?
All the connections should be marked on the board itself. If it's the three on the top righthand side you're after they are (top to bottom)
earth, ignition switched 12v, and permanent (battery) 12v.
many thanks chaps .. will have a look and see if i can work it out of the diagram
