how?
kj - 16/12/06 at 05:33 PM
What is the best way to secure my sierra harness. Are cable ties ok or is it best to use p-clips.
Humbug - 16/12/06 at 05:51 PM
I think the "recommended" way is P clips if you can find them big enough. I actually used cable ties threaded through cable tie bases which are riveted to the chassis. There are self-adhesive versions as well, but these are frowned on because they are not "permanent" enough.
Mine are like this (but not from here):
David Jenkins - 16/12/06 at 05:57 PM
I nearly failed my SVA 'cos I used self-adhesive tie-wrap bases in some places. The tester and I reached a compromise...
stevec - 16/12/06 at 06:22 PM
You can use screwdown cable tie bases and cable ties, Quite neat and easy to alter should you want to add another loom to the run.
Steve.
