right i have the sierra main beam/indicator stalk in my car and have the later/thinner wires so can someone please explain, in laymans terms, how i
wire the stalk to operate the main beam and relays as im really struggling and this is the last wiring job to do
please help
james
Wire your lights through the relays then run the relay earths through your column switches, brown/yellow dip, brown/white main beam. Make sure you have the earth from the left stalk to the right when you switch from side to headlight brown/black joining terminal 15s on older or 56s on later (there are still two variations)
right well i have the sierra indicator stalk but not the light stalk. for lights im using an off/on/on toggle switch and have dip beam working. i need
to work out what the 4 brown wires that my main beam switch has do. one i think will ne permanent live for the main beam flash. then one must be a
live feed from dipped beam for normal main beam use on must be a feed to relay and on to lights and the other an earth?
are my assumptions right or am i totally off the mark?
james
I've got a description of a 2 relay (main and dipped) system for Sierra stalks on my website but thats probably not much use if you're not
using the lighting stalk and shows the connection to a STM loom anyway.......
Have you got a copy of the Sierra Haynes manual- the wiring diagram isn't great (black and white) but with that and a multimeter it is possible
to work out the connections you need..... Or that's what I did...
ps U2U me if not!! I know of a backup copy of the Haynes manual online. Obviously you need to own the original too for it not to be illegal.....
ben im even more confused now, lol
i forgot to mention im using the vicky green loom with the relay kit but still cant get my head around this
(told you i needed laymans terms
james
