running loom in the car?
ch1ll1 - 16/2/07 at 08:45 PM
hi all
is there any rules stating you can not run your wiring loom through the car it self?
im thinking of doing this but would make a box section for it to run through
can anybody see any problems?
cheers paul
[Edited on 16/2/07 by ch1ll1]
nitram38 - 16/2/07 at 09:15 PM
Loom can be exposed anywhere as long as it is mechanically protected.
Either use split flexible plastic conduit or spiral wrap.
Box section is a bit OTT
[Edited on 16/2/2007 by nitram38]
zxrlocost - 16/2/07 at 09:15 PM
wouldnt it look a bit messy or out of place?
cant you run inside edge of top of tunnel
chris
RazMan - 17/2/07 at 11:21 AM
Maintenance would be a real PITA when you need to run any new circuits that you forgot about ........ which is inevitable
I used heatshrink for any exposed bits of loom (engine bay, lights etc) and spiral wrap for the internal bits.
