OK ..Just need to finish the wires of to the coil and I am ready to start the engine
Last couple are the two from the dizzy..One white and one white/Black - where do they go?
Paul
I'd say white is from the Ignition live and the black/white is a speed signal either to the ECU or as quoted from the haynes "ignition pick
up point!!"
Info gained from here TVR wedge pages
ATB Dan.
[Edited on 12/3/07 by scutter]
I'd guess one is earth the other is the signal wire to the coil, if it's anything like my mates rangie. Can't remember which is which, but a simple try it and see should sort them out.
So as I see it ( which could be wrong!!)
The white is connected to a positive feed from the ignition and the same feed goes to the coil +
The white black is connected via the coil to and earth?
Paul,
White black is feed to the EFI brain if Fitted if it is it needs a resistor in the wire or you will fry the EFI brain.
The white one to the Coil Neg - ( i think but let me check that )
I have it in this blasted computer somwhere and it hidden it from me
regards
Agriv8
White goes to Coil POSITIVE ; White/Black goes to coil NEGATIVE assuming that's a 35DLM8 which it looks like it is
I concur on that, both go to the coil. Good to see the wires have gone brittle, living up to BL standards !
Hi Paul
I kind of agree with robinj66.
Looking in the Rover manual it shows a red and black going to the ballast resistor +ve then onto the coil +ve (same terminal on ballast
resistor as ignition key live which is white like all other rover ignition +ves). The white and black then goes directly to the coil -ve.
Also, checking the mallory website instructions I found this http://go.mrgasket.com/pdf/Unilite_Wiring.pdf which agrees totally with that.
Enjoy the first clap of thunder form the engine - it will make you smile for days!
Mark
New I had it somewhere ( hidden in one of my RR PDF mannuals
doesnt help with the wire colours but shows the idea
dizzie
Regards
Agriv8
