MBE 941 ECU or other ECU maps on a pinto?
se7ensport - 17/3/07 at 10:17 PM
Anyone using one of these, idealy on a pinto?
I've just downloaded the software to see what the funcationallity is like before purchasing and it's not as self explanatory as I had hoped, is it straight forward to use when an ECU is connected?
does anyone have a base map for a pinto with stage 3 head?
I'm also considering other ECU's and if their are pinto maps out there that I can use it might sway the decision
