In "The Book" Ron talks about using modified Mini wipers on the MKII wiper studs. I have the wipers now and do I cut the end of the arm and try to put a new dimple in it ou do I drill out the rivet and cut that end and rerivet it back together??? Tks Russ "across the big pond" Amos
I have drilled out the rivets on mine and cut that end, then used a couple of 3mm rivets to put it back together.
john.
Is that a pop rivet or a hammer type rivet???????Russ
just a couple of pop rivets in mine.
hth.
john.
