DIGI DASH 2 LITE PROBLEMS???
hardtoregister - 21/4/07 at 04:22 PM
Hi guys,
got a problem with the digi dash lite, its not reading speed or gears and constantly says (when driving in gear) that the clutch is in!!
any ideas????
all the info is filled out although not entirely sure if i've got the correct primary ratio or pulse settings.
i have a fireblade engine and i have set pulses to 4 and the primary ratio as 1520??? is this correct???
cheers
bigrich - 21/4/07 at 05:12 PM
sounds as though the speedo pickup is either too far away from the magnets /magnets upside down(should be dimple down i think) or is the plug in correctly on the back of the unit.
have you done a proptest in settings to check the output of the senser
it wont indicate gears if speedo is inopas it uses a calculation of revs and road speed to work out which gear its in.
DarrenW - 23/4/07 at 03:05 PM
I seem to think the pulses should be 2 if using a 2 magnet system. Try changing it to see what happens. I also had problems with gear display when i incorrectly entered the gear ratios.
