Hi all,
Has anyone got a wiring diagram for a 4 pin relay.
From the case, I've got pins 86 and 85 going into a rectangle with a diagonal line through it. I take it these are the pins for the low current
switch side and the rectangular thing is a coil to attract the switch of the high current circuit and switch it on.
Also got pins 30 and 87 which go through a switch - I take it these are for the load ie, horn.
Pat...
Yes, correct.
The rectangle is he coil, the swith is the contacts you use to switch power to the load.
