Having tided up the garage and sorted all my receipts and paper work ready for SVA application (provided the engine works ok) I seem to have lost my
loom info.
Could some one save me the time of going through my sierra diagrams and tell me what the following wires are for on a premier loom (rear section )
They will be rear light clusters and fuel tank sender + pump
Black / White
Blue / Black – Fuel sender ( at least that is where I connected it last year! )
Black / Purple
Black / Yellow
Black / green
Black / red x2
Slate / Black
Slate / red.
I have had two pints already with my lunch and don’t fancy trying to use my brain..
Paul
Black / White - ns indicator
Blue / Black – Petrol gauge
Black / Purple - Reverse light
Black / Yellow - Fuel Pump
Black / green - os indicator
Black / red x2 - Brake lights
Slate / Black - os tail light
Slate / red - ns tail light
HTH
cheers...
I have the Luego loom instructions and relay diagram in a word doc if you want it?
(I have found that some of the colours in my loom aren't quite the same but it helps find the right ones!)
I cannot upload a word or PDF docs to the photo archive so if you would like a copy drop me a U2U with your e-mail address
Mark
[Edited on 27/5/07 by Paradoxia0]
